03.10.2010, 02:48 PM
If you can get them to startup properly you will be ok.
Most outrunners have a shaft that can be pressed to stick out the front and back. That way you can install a cup for the dogbones on each end.
6s is the way to go, and I can recommend axi as a good motor choice. I have a few of the 28 and 41 series outrunners and they do very well.
