SpeedAssault
SpeedAssault's Avatar
03.11.2010, 12:30 PM
Originally Posted by littleazn248 View Post
ohhh ic i thought they were the big bores. In that case you should be fine there 16mm right? Yeah 60 wt is good but i think losi might sell progressive rate pistons. As far as it goes i think all you need to tamper with now is the springs.
cool thanks, I will switch up the springs, much easier than changing oil
What do you drive ? in Ca?
