Originally Posted by JThiessen
Why yes it is....!
I'm wondering if I'm running out of RPM's with the 1520. I charged up the pack, and ran it again. Same story on the speed. Probably tops of 30mph. Speed calc has it hitting 50 with my gearing, and I'm getting nowhere near that. Might try to completely reset the MMM too....
Hey, you guys that have Muggy's. Do your diff's sit kinda loose in the "bulkheads"? Mine have about 1/8th inch of vertical movement in them.
Jeff, are you calculating with Muggy diffs? The ratio is taller(slower) than LST.
What pinion are you using? And 6s I take it?
I wonder whats up with the speed....
