After a busy week of school and soccer and getting a job at a local movie theater.. I made some progress on the Evo8. First I cut up the Revo drive shafts and put a male half shaft in the middle of two female shafts to make the center drive shaft. Then I cut up the Rc8 steering top plate so the drive shaft could fit. I also had to grind a slot in the bulkhead upper deck because of drive shaft clearance issues. After I got the center drive shaft taken care of I took the parts I had used from the Slayer drive-shafts on the center diff and replaced them with the new Revo drive-shaft parts so that I had complete Slayer drive-shafts.
I got the mudguards mounted and had to cut down the chassis slightly in the front to make them line up. I think those turned out great.
Next, I mounted the Tekno motor mount by drilling slots in the chassis. As you can see from the pictures its alittle crooked so I will have to fix that with alittle bit more drilling.
Lastly, I got a piece of black vinyl from a teacher at school for free and decided to try wrapping the chassis in it. Its a little bit shinier than I would like and also has quiet a few air bubbles in it. I figure you won't see too much of the top of the chassis once all the electronics are in place.I didn't wrap the top decks yet becuase I'm still trying to decide if I like it.. what do you guys think? I know on the bottom with the vinyl or with it I will probably be a lexan chassis guard and so I really wouldn't need the vinyl on the bottom since I would paint the chassis guard black.
I also just ordered some 17mm adapters from a guy used for $7 shipped. He isn't sure what brand they are but he says they will fit so I'm hoping they will do.
