thzero
03.25.2010, 03:26 PM
52.62mph is what BG's says. I was going with it because people were mentioned it was a good combo.
Was gonna try going down to 50/14 which is a "46.05".
I will say though, belting the tires (I did the insides with gorilla tape and outsides with 50lb test fishing line) means very minimal if any ballooning!
Doesnt sound too bad- what speed is that geared for with your setup exactly ( I would pump the numbers into the calc but Im lazy :P )?
Doing speed runs will heat things up a bit more vs normal bashing argueably, so I wouldnt be too concerned- just allow the motor and esc to cool down every now & then between runs, then bash/ speed run some more. :)
