Originally Posted by itbvolks
I'd actually like to see Mike incorporate the Mugen outdrives for a small weight reduction (anything helps).
You should be able to use your Mugen outdrives (and many others for that matter) with the Slipperential. I'm not sure what outdrives come with the Slipperential, but the inner diameter was too small for my CVD shafts so I used my stock Caster ones (basically same as MBX5T) and they fit fine.
