E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.29.2010, 09:40 PM
I ran the maximizers for awhile both on my revo and my truggy. They are not worth it and are a big PITA!!!! When tires are glued properly they hold up well, if you can't glue them right then get premounts. You can bake the tires and rims and they come apart pretty easily. If gluing chrome rims, scrape the chrome off the bead area or use a sanding drum on a dremel to remove it. When a beadlock rim lets go of the tire you pretty much have to take all the screws out to fix it. If a glued tire starts coming loose you put a little more glue on, so much easier
