itbvolks
03.31.2010, 09:41 PM
Wallot,
Curious how you've found the aluminum drive cups to work (not sure if you ran them on your MBX5T setup)?
Picked up a set for my racer and hoping they hold together reasonably well. Clearly a nice light setup with regards to the rotating mass of the driveline. Hoping it actually translates to quicker spool, less heat, less driveline loss.
Truck looks great. I'll agree, I prefer Mikes mount for the lower CG. I'm omitting using Mike's servo tray (like you have) so I can mount my transponder/Rx lower in the chassis. Need to see how it works out.
Curious what gearing your running? I went with 16/46 with my Tekin 1700kv setup. I'll be running this on Hyperion 5S (still working on capacity).
