jhautz
jhautz's Avatar
04.02.2010, 09:33 AM
If you are pulling enough power that the 13ga wires are to small then you probably will have bigger problems. The MMP will hit its current limits before the 13ga wire does. So if you think that the 13 ga wire is to small for your application then the MMP is also probably to small for your application. Look at the MMM or RX8.
to make it...
or break it...
Silent...But Deadly
