Semi Pro
Semi Pro's Avatar
04.08.2010, 09:28 PM
Differential Ratio: 3.3076923076923075 (Lst 2 Diffs)
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 1
Pinion Tooth Count: 1
Total Voltage: 18.5
Motor KV: 380
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 1 : 1
Total Ratio: 3.30769 : 1
Tire Circumference (inches): 18.06 inches (458.83 mm)
Rollout: 5.46:1
Total Motor Speed: 7030 RPM
Vehicle Speed: 36.36 mph (58.4 km/h)
Effective KV Value: 380
KT constant: 3.56 oz-in/A
