thzero
04.09.2010, 09:34 AM
Fixed the link, but here it is.. http://www.rc-monster.com/proddetail.php?prod=rcmcdmm. Its the Universal Center Diff/Motor Mount.
Ah, may have to check that out... I've been using a combination of cheap ones because they do some things well, others crap.
Yes, very true about the CoG. However if say going with the something akin to what you drew up or Mike's Universal mount, the size of the spur hardly matters as the motor is up above the CD so the CoG is going to be much higher due to the weight of the motor of course.
Here's what I've drawn up, at least one of three. Its based on the RC8 center diff (because I have one to measure in my RC8Te!) and is as low as I can get it. This uses custom dogbones, I've got another one that uses the tCS Crawlers 5T conversion front dogbone (12") but I like this better as the other one has some higher CoG and some chassis issues. These are about 11" and 5.4" dogbones. I think HotBodies may make a 134mm dogbone, so adjusting the cd back about 4mm would mean only one custom dogbone.
The other that I've drawn up uses Mike's Universal mount with custom dogbones. Its a little nicer in that it all fits within the TVPs and no cutouts on the side for clearance. You can also get to the engine, adjust the mesh, swap pinions, etc. much easier with it. Its just that the CoG gets jacked.
Originally Posted by Nard Cox View Post
He's not using Mike's because ; Sorry, this product is not currently available.. Could you link it again?
That is no CAD design, it's Google Sketch-up
About the gearing. A higher spur indeed gives you more flexibility, but it also raises the CoG more and more. I will have to give this project some good thinking before I will start it.
