itbvolks
04.09.2010, 09:39 AM
Nice, sounds like you sorted the issue. This still running the 16/46 gearing? Good temps to be at.
Sensored motors are just taking advantage of rotor position at zero/low rpm. Helps with cogging and initial low rpm throttle transitions. I'm 95% sure even the tekin setup goes sensorless once your through that initial transition period (not exactly sure where it occurs). Sensored should help with braking and transitioning on/off throttle and probably a little with mid-air corrections but once the motor is into it's rpm range, it's running sensorless.
