MikeW
MikeW's Avatar
04.10.2010, 11:10 AM
If you bought a controller for 8s, I think this motor would work very well in your conversion. (If it fits) Turnigy Aerodrive XP 63-64 230kV The motor shaft is 10mm so you would probably need to turn it down, but otherwise it should have plenty of torque. Same RPM, same rollout, same speed- higher voltage, more torque, greater efficiency.
How would you be able to mount the output shaft on the back of this motor?
I would be interested to do a savage 8s outrunner with this and the HC 8s-12s
