E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.13.2010, 12:41 AM
Went over to my friend's place tonight, re-installed firmware 1.24, reset to default and then just changed the motor type to brushed reversing. Still doesn't work right, now I have reverse with brakes in reverse but no forward. I know it's reverse cause the speed changed as I played with the reverse power. I also tried all the old firmware versions and had no luck. So I wanted to rule out it being a funky motor problem or wiring problem. I pulled my MMM out of my E-maxx that is broke in half and used just the field programmer to set it up, it works flawlessly! Guess something is wrong with the MM, gonna send it in and upgrade to the MMPro.
Overkill?
