04.16.2010, 11:44 AM
Don't forget; once you get the outputs paralleled, monitor heatsink temps after a few minutes of heavy operation. Shouldn't be a problem since it's really a single rail, but any regulation differences between the two coils/regulation circuit may cause an issue. It should be quite obvious after only a couple minutes, but I think you should be fine.
