Semi Pro
Semi Pro's Avatar
04.16.2010, 11:46 PM
looking good so far, sounds like you have put some thought into it, are you planning to make lower shock towers, might help your cg some as well as trying to narrow it up as much as possible.
if i were you i would put the servo on the motor side and put the battery infront of the esc, that would be more compact and balanced
