itbvolks
04.17.2010, 03:19 PM
Alrighty....
Got the power supply up and running and seems to be outputting power as per it's specs.
Hooked up the 720i and setup to charger my 5s 4200 Hyperions. Trying to charge at 2c so 8.4A @ 12v. Problem I'm seeing is some pretty significant voltage sag. Charger is reporting ~10.6v input and I'm reading 11.1v with my Fluke loaded. Unloaded it's running about ~12.2'ish
Not so hot. Matter of fact, seems as if the charger stops charging for ~4-5sec every so often. No error report and doesn't terminate the charging cycle but assuming a low input voltage issue....
