04.17.2010, 04:35 PM
Issue 1: Did you attempt to load the 3.3v and/or 5v line(s)? Sometimes that makes the 12v line more stable under load. The PS mod thread explains this, and what values to use.
Issue 2: If the charger's input voltage is correct, there could be voltage drop on the input power leads. My old EOS7i came with really long (like 6') cables. Shortening them helps a LOT.
