MetalMan
MetalMan's Avatar
02.15.2006, 09:52 PM
That depends upon how many cells you will run. If you will only run 6 NiMh or 2s Lipo, then the Feigao 380C 6t will work well (for good speed). If you want a lot of torque with better runtime, the 6L is good. Each motor will run differently on a certain number of cells (can be seen from the kv), with the slowest motor (13t) running on 12 cells or 4s Lipo being the most efficient (thus the most powerful/torque-y).
