04.19.2010, 05:54 PM
The plastic Kyosho spur is holding up fine. No uneven wear on the tooth profile. The runout is good since I'm using aluminum center diff mounts on both ends. It really helps in making the rotation true.
I just read your thread and I'm glad you're happy with the RX8. I still have to change my pinion to 16T. I had been lazy lately doing other things (running my speed truck). Hope you can get everything sorted out.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
