What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.19.2010, 06:18 PM
If the jumper is the problem, would a couple high-current diodes from the pads leading into one wire help? Since the diodes would block the voltage from one pad to the other they would retain their individual regulation but feed into one output. I am assuming the low output is from interference within the current sensing circuit on each pad.
