itbvolks
04.21.2010, 10:51 AM
I would think a couple of this in parallel would work very well with a HS. I can't describe the difference adding the load to the 5v made. I went from running 4.2A loaded with a main line voltage of 11.3v to running 8.4A loaded with a main line voltage of 12.34v rock solid and I'm sure more is available if needed. At the 8.4A loading prior, I was in the ~10.4v range and the charger would shut down.
I was measuring some V-drop between the PS connectors and what the charger was reporting as well (up to .5v). Now I measure 12.4v at the PS connectors and the charger reads 12.34v.
Matter of fact, now that I know how to make this work, I might grab a few of those myself...
