thzero
04.23.2010, 10:28 AM
I used the 47 because I converted from an XSS/XL nitro Savage. Whatever pinions fit on the Flux with the standard Flux 44 spur will work. The mounting for the flux motor, gearbox, etc. is exactly the same as on the Flux.
Originally Posted by danielc79 View Post
do you need to go up to a 47 spur or will a 17 or 16 pinion fit the stock 44t spur? i'm sure theres limited adjustment but want to save the cost of the spur if i can. thanks
