ANGRY-ALIEN
ANGRY-ALIEN's Avatar
04.23.2010, 10:41 AM
Originally Posted by nuz69 View Post
Yes its to prevent dust and thing to go the the fan, I had issue with blocked fan on my other MMv3 case :(.
I was little disapointed by the temp at the end of the run : 135F motor (ambient temp 75 and i only drove under sun) and ESC Fan always on, but I completely closed my hull.
Hmmm... what kind of material are you using to cover the fan? It staying on for long durations could simply mean the airflow has been reduce dramatically and the fan is not
allowed to do it's job efficiently... If you need to reduce the amount of 'dirt' entering the fan, try something like a fine mesh... The temps for the motor aren't all that bad...
I found the below setup in the 1520 thread:
Differential Ratio: 4.6
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 15
Total Voltage: 22.2
Motor KV: 1600
Tire Diameter (inches): 5.65
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 3.07 : 1
Total Ratio: 14.10667 : 1
Tire Circumference (inches): 17.75 inches (450.85 mm)
Rollout: 1.26:1
Total Motor Speed: 35520 RPM
Vehicle Speed: 42.32 mph (67.99 km/h)
Effective KV Value: 1600
KT constant: 0.85 oz-in/A
Maybe if you try a smaller pinion (if it's available) you could see lower temps... ... at a full charge of 25.2 volts (approximately), a 14 tooth will yield 44.84 mph (72.03 km/h)
and 13 tooth will get you to 41.64 mph (66.88 km/h)
Don't forget the vids
Alien
