pinkpanda3310
pinkpanda3310's Avatar
04.26.2010, 07:16 AM
I decided to try a drop down center plate, and reversed the center diff and motor to get more of the cg to the front. Had to mock up the servo and front shaft to make sure there was clearance.
Am I looking at it wrong or are the chassis rails facing the wrong way?
For more rigidity you could extend the rear skid to connect with the centre. Didn't you pick up a hot racing chassis? you could run that current set up with a similarly low cog. Or is that a an XXL chassis in the mock up?
