Originally Posted by Nard Cox
Hi guys,
Recently I was jumping my RC8Te in my garden when the car suddenly stopped. It didn't do anything anymore but the magic white smoke was still inside. So I decided to check the switch and what do ya know, it failed on me. So after removing the switch it worked perfectly again. But just before I wanted to call it a day the car did.
I brought it inside and to my surprise I couldn't get the ESC to turn on anymore (tried different LiPo's, disconnected and connected all the cable but nothing worked). The switch cables were still solidly together and all the other cables seem to be fine as well. I tried the ESC in my Flux XL but no response there either.
I just hooked it up to my PC and it works flawlessly on there (first I loaded standard settings but that didn't help, after that I upgraded the firmware from 1.21 to 1.24 Beta but still no response). So I decided the check the inside for any damage or what ever but everythings looks perfectly fine.
Does anyone have the golden tip for me to get this thing running again??
Thanks!
Greeting from the noob.
From your description, you may have cracked a part or a solder joint. Send it in, we'll get you fixed up.
Patrick
