Originally Posted by redshift
That truck's gonna rip some tar!
Looks good Bro
Thanks J. !!!!
Everything is all together and ready for testing. I did the 4mm hardware shock mod and I've reinstalled the LST diff gears and changed my viscositys to a lighter weight. I was running 50,000 and was breaking the pins under the sun gear pretty frequently and thought maybe a lighter fluid will let the other tire unload rather than grip and snap ? So I'm trying 15,000 for giggles ?
Have the tires mounted up and will finish glueing and balancing tomorrow, I have to solder on the EC5 plugs to the ESC and my 5s packs then test with a5s pack and 2-3s in series and see what happens ???
6s packs in route.
LST sneakers, nylon taped and mounted up to a set of (NOT DYED) 23mm PL Wabash rims w/1/2" off set.
