JThiessen
JThiessen's Avatar
04.30.2010, 10:22 AM
Intersting info there MC. I can see right now that I might have an issue on mine if I use the Muggy steering. My center shaft is going to be angled towards the servo, and slightly up from center.
When you did the mod to shorten the post, are you certain you did it from the correct side? I seem to recall from reading about someone else who did this that they did not have to bore out the bushing hole....but I am not certain about that. I almost wonder if they didn't instead grind out the chassis rail.
