mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
05.01.2010, 11:19 PM
Intersting info there MC. I can see right now that I might have an issue on mine if I use the Muggy steering. My center shaft is going to be angled towards the servo, and slightly up from center.
Maybe you could flip the whole assembly the other way and have the lever on the other side, you would have the adjusting collar for the tension near the top plate instead of the bottom but IMHO, this collar is adjusted once for the desired tension and then you never touch it again. It is not an adjustment that you mess around with constantly. If your shafts are slightly off center that means you would have enough clearance since I found out that only a half mm more is needed for the lever not to touch the shaft.
When you did the mod to shorten the post, are you certain you did it from the correct side? I seem to recall from reading about someone else who did this that they did not have to bore out the bushing hole
So what makes you think their way was the right way Seriously, there's more than one way of doing it, I did it my way and it works pretty darn good.
I did a lot of stuff today. So my fear of the bellcrank touching the shaft materialized today. I ended up shaving a tiny bit off the lever for clearance so that it would work in this plexi mock up. I will solve this little problem definitely when I make the CF top plate and the aluminum part that goes over the front skid plate by spacing the two bellcranks 2 mm more apart. 1 mm on each side which will take that lever away from the shaft just enough so that it doesn't touch.
I tried with the inverted servo set up and it just bugged me. Don't know why but it did so I flipped the servo right side up and I just like it better that way.
You will notice that this top plate looks kind of grungy and the openings are too large and the cuts look awful. This is only a mock up. The finished product should look a lot cleaner.
This middle skid is not exactly what I intend to do. I just duplicated the stock middle skid and added wings to it for the batteries. The final CF skid will be more refined and look more elegant than this.
But it does place the batteries nice and low. But not too low.
I had a couple of those alu plates that go under the shock towers so I took one. cut it, grinded it, sanded it, drilled and tapped it and made this.
It goes there in front of the rear shock tower to hold the Traxxas receiver box.
This will be the final layout. My original plan was to put the MMM in the front but with the size of the 1521 1Y, it looked a little cramped so I decided to place it just behind the tranny. I just think that it makes the layout look cleaner and it gives lots of room to work on anything.
I wanted the tranny to be in the absolute center but the XXL middle shafts were just a little too long so I had to off set the tranny 4 or 5 mm to the rear and use a LST2 middle shaft in the rear. With the XXL middle shaft in the front, it all went together very well. The drive train rolls very freely with no binding.
On a side note, I took the whole thing with the batteries on it in my hands and let it drop from 2 feet high and was amazed at the amount of damping these big shocks give the truck. This thing is a jumper for sure.
No brain, no headaches.
