Overdriven
Destroyer of Tires
Overdriven's Avatar
05.03.2010, 10:10 AM
As far as the rockers go I don't think aluminum is necessary as I've heard of only 1 person breaking a rocker. You might want to try p2's instead of the long travel though. The long travel raises the truck up, but also provides the suspension alot of leverage against the shocks. Switching from p1 to p2 made a big difference in the handling for me. And I am able to maintain good ground clearance, close to what you have now, by moving the pushrods to the inner holes on the arms. I just need stiffer springs to support the weight with the electronics on it. This is assuming you're not perfectly happy with the handling and want to change it of course. Hope this helps if you do.
