brushlessboy16
brushlessboy16's Avatar
05.10.2010, 01:24 PM
Well, in the e-8 conversions, the differential gets spun around 180 degrees. Anything larger that a 45T spur will need some grinding on the chassis or a slot cut for the gear to clear. This is the case unless Mike's new mount will provide a spacer/riser for the differential.
Not entirely true.
mikes CURRENT mount has the spacer for a 48t....
