mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
05.12.2010, 11:51 PM
The stock plate is 2.5 mm aluminum with a thousand holes in it for the tranny, the gears, the multitude of servos and what not. The CF plate is also 2.5 mm thick and has much less holes in it and CF is stronger than aluminum. If the stock aluminum plate is strong enough then the CF plate will be more than adequate.
On another note, I got myself a HPI FLUX motor mount to use for the rear of my 1521.
No brain, no headaches.
