josh9mille
josh9mille's Avatar
05.13.2010, 03:08 PM
The 3s Lipos from HC have a board everything is soldered to. If you remove a cell you'll still have the bigger board ?
The bad connection is probably the balance tab ??? I've have a lot of them go bad.
I want to keep it a 3s with one of the cells from my 2s pack. Im pretty sure the cell in the 3s pack is ruined when i checked the voltage on it it was .58 volts.
