Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.16.2010, 05:55 PM
That's only an 80A battery, which is just not enough for the MMM/2200kV, nowhere near enough actually, and you risk burning up the ESC if you keep running it.
I know the Vorza is not as big and heavy as an MT or Truggy, and the tires are quite a bit smaller, but 80A just isn't enough for the Monster. I suggest you buy a new battery, one with more capacity and higher discharge rate. Since you are looking for more run-time, a 5000-5800mAh 30C battery will be perfect for you. The very minimum I would suggest is a 25C 5000mAh battery, but I highly recommend a 30C or higher battery. Plus, a higher discharge rate battery will improve run-time since it supplies more amperage to the ESC/Motor, allowing them not to have to work so hard, which increases run-time.
Either a Zippy Flightmax or Turnigy LiPo will be perfect for you, and they are very inexpensive. I personally run nothing but Zippies and Turnigies in all of my vehicles, including my BL Revo 3.3 with an MMM/2200kV combo.
Let me know if you decide to buy a new battery (which I HIGHLY recommend), and I will help you pick out the right one.
-Chad
PM ME IF YOU HAVE THE BELOW:
