simplechamp
simplechamp's Avatar
05.16.2010, 09:53 PM
I am pretty sure you have it wired wrong there Chadworkz. I might be reading which contacts are for which labels, but I think the batt and load have a common ground or negative.
God, now I am so confused.
Isn't that exactly the same as the diagram above though?
It has the same common ground, just that circle load is.. uh..
Chadworkz diagram is correct, the one zeropointbug drew is the same but drawn a bit differently. They are both right.
