simplechamp
simplechamp's Avatar
05.16.2010, 10:14 PM
Look at the original diagram from the site, the one Chadworkz posted. The battery goes to the far left and far right pads, and the JST plug goes to the 2 left-most pads. You just need to make sure the polarity is correct, and they are labelled on the board.
The original diagram is drawn exactly as you need to wire it. The symbol on the top represents a voltage source (in this case a 3.7V lipo) and the bottom says load/charge, which is where you have the JST plug to connect to the charging circuit and also use it to charge the lipo.
