zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.19.2010, 11:08 AM
No way! Tell me how that makes any sense? Seriously, we all know a 6s 3000mah is just a hazardous as a 3s 6000mah... is that what they are saying? This is beyond retarded if I understand what's going on. I am lucky I run a 6s setup, only need max 4000mah, otherwise I would be running 6000+ with a 4s pack. So what brands does this apply to? Where are these rules coming from?
Wallot, good to hear, and do let us know. Do a cell check before you use it, and do a couple soft cycles on your charger before you use them, and then go easy on them for the first 10 cycles at least in your R/C. Should get some serious power out of them after that.
