Semi Pro
Semi Pro's Avatar
05.25.2010, 04:11 PM
Feel free to give me a call to discuss but not sure that this will differentiate that much from the Novak dig unit - I use one and it works quite well but can glitch when switching modes sometimes.
I'm not sure its worth your development time to do just this...For $20 the novak unit it does what it needs to do...
However if you wanted to try this as a beta of creating a combined ESC that could work - i.e. I could try de-casing a couple of MMP's, a bec and this unit into a single package - That would be good and then look at simplifiying packaging if it works well...
Sorry but the internal bec's just don;t seem to cut it in crawler use - It might get better if two were linked but the CCBEC works best with the voltage adjustability and high amp support...
Rgds
agreed a single package is the important part, there are already afew company's that make units that let you use 2 esc with dig and so forth but alot of us dont have room for 1 mmp much 2 and an accessory board
keep in mind alot of people use the mamba 25 as an esc, we dont pull alot of amps and normally get 45min run time on just 1600mah
one thing that would be great would be if the esc could handle 4 cell, im sure novaks will only support 2 cell
