Originally Posted by bigsteel
60 amp esc? Figured a boat needs much higher requirements than that? Maybe drop a MMM combo in that bad boat!--josh
A 60amp is plenty,thou i run a 120 amp turnigy esc in mine. You need a water cooled esc, because it is sealed up in the boat, with no air circulation. I use a 60amp esc in my Aquacraft UL-1 & it runs great. The motor & esc in this boat are used in alot of the spec classes.
http://aquacraftmodels.com/boats/aqu...ior/index.html
