crazyjr
crazyjr's Avatar
05.27.2010, 08:47 PM
I have been wanting something like this in a 1/10 scale castle motor (2000-2700kv), on 2s lipo. My belief is, the motor kv is an indication of powerband, While they all make the same power, Theoretically, They make it at different places on the RPM spectrum. For instance, the HV 4.5 (5000kv) and the 10.5 (Roughly 2000kv), While both make the same power under load, The torque band will be lower in the lower kv motor. Plus with the lower kv motor, you have the headroom to raise the voltage and gain from the efficiency of using less amps over letting the voltage do the work
Almost forgot, My plan for one of these is in a CRT.5 on 5s geared for mid to upper 30's
