ta_man
05.28.2010, 10:53 AM
Originally Posted by hlb14 View Post
so which would be better suited for an rc8 on a tight indoor track limited to 2s lipo? i did the math on a 5.5 being 3700kv geared 17/46 to equal roughly 28 mph and ordered a 5.5... then i read the tuning rotor that comes with the ballistics reduces the kv by 20%. Would the 4.5 work better? O, i will be using a mmp if that helps, thanks
You should also consider that the Novak motors don't reach rated KV under load. I tested a HV6.5 in a 1/8th buggy and it was running at only 3000KV at the top speed of the car (on 4S geared 9:46 with standard buggy diffs) vs the rated KV of 3400.
