wallot
wallot's Avatar
05.30.2010, 10:16 AM
Great race this weekend. We did run 3 10min qualifiers and 3 10min finals.
Had to use 4200mah battery (the new 45C/90C G3 hyperion) as I did not want to push the 3300mah to the limit. (put back about 3000mah after each run)
Truck still needs some minor adjustments will go from 20-20-8 in diffs to 20-20-10
Rest of the setup will stay the same.
I did redrill rear shock piston holes to 1.5mm so the suspension works faster on a broken track and it did really help.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
