Overdriven
Destroyer of Tires
Overdriven's Avatar
06.01.2010, 10:33 PM
I happened to be in my lhs when a guy brought this in so I snapped a few pics. Its a King Motors clone with every (king motors) aluminum part installed, running really tall rear tires. Proline moab XL's on 23mm adapters I think, alot taller than stock either way. Thats a 2215 1Y in there powered by a hobbywing 150, he's got 2 6s in parrallel. Claims he's seen 38mph on radar and it has more in it, but was limited by space at the time. Also told me a 5b body won't fit, it'll hit the gear on the jackshaft. No mech brakes on this one, don't know if its possible with this kit. I do know he bought the car from Dan setup like this, but with a MMM. He's hoping the hobbywing won't go up in flames like the MMM did. Yes I explained why neither would survive very long and what he needed to do. He then mentioned Dan told him a 1/5 esc was coming from hobbywing that would solve the problem. Anyway on to the pics.
Edit: Chadworks, there are two bearings supporting the shaft, one on each side. They go in from the gear side, I guess that way the gear helps hold them in place? Dan told him the dual motor setup had synching issues so it was scrapped. But he kept the shaft so you can't run a 5b body without cutting it for gear clearance.
