JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
06.04.2010, 06:23 AM
[QUOTE=Jahay;368239]thanks for the links and explanations, sounds pretty simple.....
Finnster - i was considering using another style of mount used on truggys which mount on its side, but this cause a few too many problems.
- It just wouldnt fit inbetween the tvps properly
- The CD would be way out of line with the diff axles
It sounds like all you would need to do is install a set of spacers to get the mount centered where you want it. Something like this should be right up your alley.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDEB4
I use them for all kinds of stuff when things just won't fit right. There is always a way to overcome obsticles.
SUPERMAXX YOUR LIFE.
