Jahay
06.07.2010, 11:45 AM
Got some more pics... And need some help...
Anyway here is the result after overtightening the nut on my axle... Drove 10 seconds and literally fell off.
I have been having bad steering problems recently... Mainly because my motor mount is getting in the way of my servo horn. So i had to move my servo outside of the TVPs... So i had to do a custom temporary job and wondering what else i could use which is stronger and more reliable... Some pics of what i have had to do...
[IMG][/IMG]
I was also experiencing steering throw problems and found out i was being obstructed by my steering bar... So i found where it was hitting and dremeled it to work properly... here is what the after math after one cart wheel
This is why i have decided to go with the GH steering assembly....
But has anyone got any advice one what i can do to replace the temporary screw that goes between my servo saver and my servo? What other things would you use?
I am thinking once i put my centre diff in and mount the motor off the motor plate, then i will be able to return the steering servo back within the tvps and use the stock connecting arm, but for now i need something else.
