Originally Posted by jhautz
Those holes are just for fixturing when he machines the parts. Not meant for Mechanical brakes.
Ah ha, that's what they are for. They look like brake pad mounts.
Being on the bottom doesn't matter so much, other than trying to match up the brake servo. Considering where the motor is mounted, the brake pads would have to be moved.
I couldn't figure out what you were supposed to use as a cam tho, and thought it was some trick I was missing.
But yes, motor brakes far, far easier.
