scarletboa
scarletboa's Avatar
06.07.2010, 04:09 PM
You can see why my transmission keeps on failing. Just cant handle all the torque i can make use of. My diffs look perfect still, and my dog bones and all shafts are holding up very well without much sign of premature wear. My axles are showing a little wear but they are fine for a while still.
I cant wait to see what its like on 9s once i got the CD in!
The reason u keep going through tranny gears is because the stock gear that wears out is not hardened steel. You need to get the hd gear. It is hardened and will last as long as the truck. I've put about 30 runs through mine and the gear looks brand new still.
