06.11.2010, 08:48 AM
Jammin X2 CRT
Differential Ratio: 4.5
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 14
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 5.65
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 3.43 : 1
Total Ratio: 15.42857 : 1
Tire Circumference (inches): 17.75 inches (450.85 mm)
Rollout: 1.15:1
Total Motor Speed: 32560 RPM
Vehicle Speed: 35.47 mph (56.98 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
And how about this one using 6S power with a 2200kv?
Other Ratio: 1
Pinion Tooth Count: 12
Total Voltage: 22.2
Motor KV: 2200
Spur/Pinion Ratio: 4 : 1
Total Ratio: 18 : 1
Rollout: 0.99:1
Total Motor Speed: 48840 RPM
Vehicle Speed: 45.61 mph (73.26 km/h)
