mohanjude
Need for speed
mohanjude's Avatar
06.15.2010, 03:30 PM
Looking good, Mohan. Don't forget to install a screw on the non-spur side top brace(mising in the pictures). I actually cut the middle of the cross brace off on my baja and kept the "ends" for spacing. Threadlock is your friend on the metal to metal attachments, too(the top brace, motor mount and brace plate, and lower plate connections specifically). That is a quite aggressive setup you have there, too(10s, 30 series motor, big pinion) - I hope you have a lot of space!
mike
I didnt fasten the left plate securely as I had to take it off to solder the wires. I have now firmly thread locked all the screws. On the left top plate there is an empty counter sunk hole where the screw would have gone into the rubber plastic / damper fixed to the engine. it is an awkard piece - do you think I need this?
