Andrewg
06.22.2010, 04:14 AM
The eagle tree loggers are pretty much the same price wherever you go
The micro logger is in my experience much easier to use. Its also cheaper to do most things with. The V3 150amps will read to 190 amps - the stand 100 amp loger reads to 120 amps - after that tere is no more data as the sensors saturate
The 150 runs much cooler, however where the wires solder to the boards is the fragile spot. It can get hot enough to melt, so check heat before sending it off for an indefnite run.
BTW have you tried the glass fibre reinforced tapes? Also 3M make some excellent polyester tapes backed with acrylic adhesive. Pricey but very tough.
